Old route numbers: 1990s
Started by Kramden, October 25, 2011, 12:26:35 PM
Kramden
A quick question for you history buffs out there.  The answers will help my failing memory.
Thinking of the early 1990s, which route travelled along Beattie Cres in Richardson?
Also while I have you in the Time Tunnel, what route number covered Companion Circuit in Flynn prior to the introduction of 314.  Was it 415, 414, 451?  I remember it was 4 something???
Thanks.
The Flynn route was the 415 on companion cres. Used to travel via the busway, through Florey, left Ginninderra, R Kingsofrd Smith, L Companion then via the current route 14/314 to the Fraser East Terminus.
Quote from: Kramden on October 25, 2011, 12:26:35 PM
Early 1990s, From Bus Book 2 & 3: route 125 Woden to Richardson Terminus. Prior to that I believe it was route 255
QuoteAlso while I have you in the Time Tunnel, what route number covered Companion Circuit in Flynn prior to the introduction of 314.  Was it 415, 414, 451?  I remember it was 4 something???
In chronological order:
1979 (when Belc Interchange opened): 451/452 (loop service)
later changed to 416 (1980/81 ?), then 415 (1984/85 ?)
1994: became 401/402 (loop service), then in 1997 405/406
Note: Companion Crescent
Kramden
Thank you gentlemen for those prompt and informed replies regarding route numbers of yesteryear.  Oh my fading memory.  Perhaps this is what you can look forward to on the other side of 50.  LOL!
Crescent of course.  Must have had my own street in mind as I typed.  I'm in a circuit.
Cheers.
