June 20, 2021, 05:37:01 AM
Unusual bus allocations
Started by Bus 503, August 12, 2018, 11:26:04 AM
Toyota Camry
It was an afternoon 200 service from Gungahlin Place to Fyshwick, in that direction.
For those concerned that Volgren artics have gone AWOL 672 was in service today.
Quote from: Busfanatic101 on February 05, 2019, 07:49:26 PM
Given that Bus 503 reported Volgren artic substitutions and their seeming disappearance (no sightings claimed prior to today) over the last fortnight, the question of what might have occurred is still unresolved.
681 was in service yesterday morning.
Also noted that 515 was operating an early morning route 252 yesterday that is normally covered by a Belconnen ARTIC.
Saw several Volgren artics yesterday morning peak heading into the city, assume they're back to service, that is, if they ever stopped being used in the first place is only hearsay.
Would it possible that the lack of Volgren artic sightings and the bring back of unused Renault's be due to the Volgren's being fixed up in the workshops for some currently unknown reason?
Quote from: Sylvan Loves Buses on February 06, 2019, 12:19:08 PM
That is one fascinating speculation. If this was the case, it must have been serious to cause a stand-down. Note that 621 has been in service a long time too. Also the stand-down would seem to be pre-planned if the return of Renaults is connected. Further, if that was the case, we can expect the Renaults to be promptly withdrawn again. A factory recall/warrantee campaign requiring all to be available at an agreed period would fit this speculation.
So far despite some evidence (no sightings, substitutions), we don't have solid confirmation of a stand-down. I find that surprising given forum members' informal contacts.
If there was a stand-down, there are other speculations such as an 'industrial' issue.
But 'straws floating in the wind' and speculation is all we have at present and speculating too much can result in mistaken information going into history. So, unless fresh information comes to light, it is desirable to now let the subject drop .
Toyota Camry
309 is presently sitting in the layover at Woden with the engine hatch open; it may be suffering from mechanical issues.
Toyota Camry
Quote from: Toyota Camry on February 06, 2019, 01:56:25 PM
An announcement has just been made informing passengers of a cancellation of a route 25 service to Cooleman Court; as this service normally operates with an Irisbus, it is highly likely that this is linked to the failure of 309.
Quote from: Toyota Camry on February 06, 2019, 01:58:55 PM
This topic is for unusual bus allocations.
528 (a bendy) was noted on route 906 late this morning. An allocation due Multicultural Festival? Or what may be routine if some Rapids are to regularly get articulated buses rostered on Saturdays. The patterns of use sees interchanges between rapid and local services, so if a 'bendy' is allocated to rapid runs it will also appear on some local runs. Not much point in TC rejigging this to intensively operate 'bendys' on Rapids as the new network is only a few weeks off.
The situation on Sundays around mid to late afternoon Blue Rapids City to Belconnen is getting worse. My partner and myself were denied boarding at the CITY stop last Sunday due to the bus being full. The following service also operated full but luckily no one had to be left behind though it was a near thing. A circumstance which definitely calls for the routine allocation of 'bendys' or STAGs now.
I am unsure if these are really appropriate as 'Playground' items.
Quote from: Toyota Camry on February 17, 2019, 07:49:55 PM
You have not stated your point; 309 was allocated to route 25, not to breakdown, hence my posting was correct, and you were not. It is recommended that you apologise to me; as I am older, smarter and wiser than you. Additionally, it is highly unlikely that you are an EL1; personally, I am one.
You might like to refer back to your original post
Quote from: Toyota Camry on February 06, 2019, 01:58:55 PMthis service normally operates with an Irisbus
It is not unusual for a service that is 'normally' operated by an iris to be operated by an iris.
... nor is it unusual for 309 to break down.
February 18, 2019, 11:18:56 AM #63 Last Edit: February 18, 2019, 11:21:10 AM by Barry Drive
Quote from: triumph on February 16, 2019, 09:40:23 PM
This entire post should have been made on "Weekend Bus Reports", rather than here since artics on weekends is no longer unusual.
But I'm slightly less inclined to be strict with off topic postings in "The Playground".
Quote from: Barry Drive on February 18, 2019, 11:18:56 AM
Sorry, I had lost sight of the existence of the very similar 'Weekend Bus Reports' (despite having recently posted to it). Quite ok by me to move the post.
Looks like 305 and 312 are running route 903 (Ginninderry Loop) today.
Quote from: Bus 503 on April 21, 2020, 11:12:52 AMLooks like 305 and 312 are running route 903 (Ginninderry Loop) today.
This is inevitable as both Honchos (100 and 101) are needed to maintain the weekday service, and but still need maintenance. Probably sometimes by Hino in ordinary business hours. Wonder if this is the first such substitution. Posssibly.
Sighted a full size bus (no. not known) Wed 22nd afternoon at Strathnairn.
114 was doing R3s tonight - quite possibly the very last time a PR100.3 will do an R3! (Not that it happened frequently anyway)
