VIN Numbers Needed
Started by Buzz Killington, June 09, 2009, 09:15:56 PM
Since a lot of you guys are out on the buses regularly, we hope you can help us fill in a few missing pieces on the ACT Bus Wiki, and the ATDB Fleetlists maintained by 'Mini Mat'
Firstly we are after VIN (Vehicle Identification) Numbers for the following Buses. These numbers are located on the Registration Labels (the same kind you have on your car).
338, 339, 340, 362, 363, 364, 365, 366, 368, 370, 372, 373
We are also after the Body Number and Date for the buses above as well as 367 and 369 - which are located on the Custom Coaches plate inside the vehicle.
Thanks in advance.
We also need 981 and 982 as well as body details for 991.
369-YS2L4X20001844227. I couldn't get the body details
The only numbers that change in the VIN are the last 4 for the Scanias so you won't have to remember/write down every number just the last four
http://www.rego.act.gov.au/public?function=REG_Registration_Status_Public_Enquiry
this might be of intrest, you place the any of the last 4 digits of the vin number in and the bus number e.g. BUS369 and 4227
and it put up details about the bus
There's nothing on that page?
posted the right link
ahhhh, very useful indeed! thanks very much luke!
Thanks  :dance:, i thought it wouldn't work with buses until i tried it
For those unfamiliar with where to find the details, here is where to look:
The VIN/Chassis/ Engine Number on the rego sticker
The Customs Badge located at the entrance to the vehicle
Edit: Or as I just found out by looking at the plate under the customs one which has all the details needed
It is actually the last 5 numbers that change on the Scania VIN.
371=YS2L4X20001854249
and a guess at what 369 would be as I only got the last 4 digits would be YS2L4X20001854227 if we go by the details we get from 371
Running that number with BUS369 on the Rego Site works, so that's another one down.
I have 367, it will be on later
I have updated the body number and date for 991 and the build date for 981 on the ACTBUS wiki. Given 981's body number is R2269, it's fairly likely that 982 will be R2270.
337=YS2L4X20001844479, ACT/002 (which is strange) and 03/04
371= ACT/052 and 08/06
So an update: 338-340, 362-366, 368, 370 and 372-373 are needed for everything.
367 and 369 only need Bodydetails
Details have been added for 982. As suspected, body number is R2270.
Just a reminder of a few numbers we need:
VIN / Body Date / Build Date
338
339
340
362
363
364
365
366
368
370
372
373
Body Number and Build Date:
367
369
